1 - 12 of 12 Posts
Alright y'all, I went back to the shop and traded in the P73 ECU that I was given for a P2P : 96+ OBD-2 Civic EX Coupe (37820-P2P-C12) ECU
MY QUESTION IS will this work with a 96, OBD-2, D15B 3-stage v-tec engine???
I haven't really heard of this ECU, which is why I am asking, and I understand that searching is key, that's how I got some of the info.
any help would be greatly appreciated!!!!!!!!!!!!!!!
THANKS AGAIN
THANKS AGAIN
You need to check out this site, there is ample info on ECU's www.pgmfi.org do a search, you will find what you need. ;)
Actually, pgmfi.org site is down, here is some info I found
Code: OBD: VTEC: VTEC Cross-over: Rev Limit: Found In:
P05 1 no 1992-1995 Honda Civic CX
P06 1 no 1992-1995 Honda Civic DX
P07 1 yes 1992-1995 Honda Civic VX
P08 1 yes ?? 1992-1995 Honda Civic D15B (JDM)
P0A 1 yes 1994-1995 Honda Accord EX
P0A 0 no 1990-1995 Honda Accord F22A
P13 1 yes 1992-1995 Honda Prelude VTEC (H22A)
P14 1 no 1992-1995 Honda Prelude Si (H23A)
P27 1 yes 1992-1995 Honda Civic EG JDM1600 SOHC
P28 1 yes 4500 7600 1992-1995 Honda Civic EX/Si / del Sol Si
p28 1 yes 1992-1995 Honda Del Sol Si/Civic Hatchback Si/ Civic EX
P2E 2 no 1996-1998 Honda Civic DX
P2M 2 yes 1996-2000 Honda Civic (NZ) SOHC VTEC
P2N 2 no 1996-2000 Honda Civic HX
P2P 2 yes 1996-2000 Honda Civic EX D16Y8
P2T 2b yes 1999-2000 Honda Civic Si
P30 1 yes 1992-1995 Honda del Sol DOHC VTEC EG/SiR
P54-G31 1 yes 1997 Honda Accord 1.8 LS (EDM)
P5P 2 yes 1996-1999 Honda Prelude (H22A)Type SH / Type S(JDM)
P61 1 yes 1992-1993 Acura Integra GSR (B17A)
P72 1 yes 1994-1995 Acura Integra GSR
P72 2 yes 1996-2000 Acura Integra GSR
P72 2 yes 1996-1999 Acura Integra GSR B18C
P73 2 yes 1996-2000 Acura Integra Type R (JDM and USDM)
P74 1 no 1992-1995 Acura Integra LS/GS
P75 1 no 1992-1995 Acura Integra LS/GS
P75 2 no 1996-2000 Acura Integra LS/GS
PBA 2 yes 1997-2000 Acura 1.6 EL (Canada)
PCT 2 yes 1997-2001 Honda JDM ITR/CTR
PCX 2b yes 1999-2001 Honda S2000
PG6 0 no 1988-1989 Acura Integra, All Models
PM5 0 no 1988-1991 Honda Civic/CRX DX
PM6 0 no 1988-1991 Honda Civic/CRX SOHC Si
PM7 0 no 1988-1991 Honda ZC (JDM EF)
PM8 0 no 1988-1991 Honda CRX HF
PR2 0 no 1988-1991 Honda ZC (EDM)
PR3 0 yes 1989-1991 Acura Integra XSi/RSi
PR3-J00 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR3-J51 0 yes 1992 Acura Integra JDM B16A EF 8/9
PR4 0 no 1990-1993 Acura Integra LS/GS
PR4 2 no 1996-1999 Acura Integra LS/GS/RS (B18B)
PS9 0 no 1988-1991 Honda Civic 4-door EX Automatic
PW0 0 yes 1989-1991 Honda Civic/CRX SiR (or auto from 90-91 Integra XSi)
You can just use the y8 ecu with the 3stage head as if were a y8, not using the vtec-e stage.
The head is the same casting as the y8 so power should be the same assuming the high rpm cam lobe is the same. I think the extra power, to make up for the 100cc less displacement, on the d15 130ps motors comes from compression, not the cam. Hope I'm wrong though.
I'm looking for a 1995 p2j ecu myself, but I'm not sure whats out there. I think this head was offered in different markets from 1995 to 2005, not sure on the different combinations with regard to manual, CVT and auto.
thanks riva,
I think you sort of see what I am trying to say....
thanks all thus far as well.....
but I would like to include the use of the 3 stages of v-tec if possible so that being said, would the P73 ECU from the integra have been a better choice to stick with since this ECU is still not exactly what I am looking for??
I was told that any 96-99 vti ECU would work?
and
I have searched quite a bit online about the P2J ECU without much reception.......
anymore help please????????
Either use a chipped gsr ecu to set the 12-16v switchover with the intake-mani-butterfly setting, or buy an rpm switch. Summit has one for $40 or so. OE ECU, the switchover is NOT solely based on rpm though, it also takes throttle position in to consideration to determine when to get out of econ mode. But yours wont do that.
With the OE Honda setup there's also a wideband processor that keeps the mixture very lean during 12v econ mode, but yours wont be able to do that either. You can set the econ switchover to like 3k rpm and just lean out your map below that. It could save you a decent amount of gas, but it probably will not come close to the mileage of the full OE Honda system. Only one way to find out though.
I would guess you could run a regular P28 chipped and tune the 12 valve mode for mileage and then tune the VTEC for high cam, and just use a rpm switch for the 12-16valve switch point. I believe the Apex-i RSM's have a rpm switch option that would work, but I will have to check on that. I have one of these 3 stage vtec engines and a 93 4dr LX, thinking of putting this engine in. The car has a 2-1 downshift grind and I have another tranny that needs to go in anyway. At $3.60/gal the 50mpg cruise and 130HP high cam are very appealing..............I'm going to tackle this and employ the work of some of the best ECU tuners around to see if it's possible to do a OBD-1 ecu with 2 vtec boards, or if not possible, at least try the above.
BTW I posted in the other post there is no OBD-1 3 stage ecu, cars in Japan are 1 year ahead of us. If you look at any car listings they have 91 EG's, 95 EK's, etc.
thanks again to both
shawndrake
and
rkcarguySI
for providing the extra information on my topic once again!!
and to all else as well, we all need to start somewhere at sometime I guess!
No Prob. When I get ready to install it I will keep everyone posted. One of my ECU tuning friends says that I can use Hondata, which has a nitrous/water injection option that triggers the NOS solenoid and allows you to add or subtract fuel as needed when it is triggered. This would work very well and could be used to trigger the first solenoid to 16V and richen the mix from the Econo-mix, but do I want to cough up for Hondata is now the question. I have the parts to try the P28 and the RPM switch so I will try that first.
1 - 12 of 12 Posts
