1 - 10 of 10 Posts
VTEC withdrawals
i "ride" yo momma
i recently purchased a vtec subharness from rywire.com to make my 93 del sol s (d15b7 *old motor*) able to run my new jdm d15b. it came with some instructions as to how to wire in the subharness but its a little confusing. i tried opening the ecu plug and pushing on the old plug pin with a small screwdriver but it wont pop out. any suggestions?
VTEC withdrawals
i "ride" yo momma
new to the wiring thing...can you explain what the release spring clip is?
you shoulda just used your old harness, and pinned in your vtec wires. theres a sticky in the tech section that has all the diagrams youll ever need
Friend of the D
I always thought Rywire's stuff was pretty much plug and play, so I'm no sure what you're trying to do. If you can't figure it out, I would contact Rywire. Short of that, you are talking about depinning something. I'm pretty sure google will help you out if you search.
1 - 10 of 10 Posts
