I read the " unofficial my car won't start thread" thanks, Guest.
When you bench test a main relay, test one, pos to 6, neg to 8, check continuity from 5 to 7, GOOD, so relay is good
Plug the Main Relay in. WHY does the ECU send power from A7 to #8 MR, and power from B9 to #6 MR. That's 2 power and no ground, so the relay does not close.
So why does the ECU send two power, instead of 1 power, 1 ground.
1993 Del Sol S - D15B7 - Stock - P06-A51 - RZ0159
Any thoughts? Thanks, Inky
