1 - 4 of 4 Posts
99 civic ex d15 minime with y8 head.
What ecu would work best but will my stock ecu work.
I've seen alot of post with this swap in earlier 90s Hondas but they are all obd1 so I'm not sure if I need to convert or if I can stay simple and keep the obd2 setup
If you can make the knock sensor work the stock p2p ecu will work just fine. If not, conversion harness to a chipped obd1 ecu that should be tuned for your setup.
In a pinch you might get away with running a stock jdm d15b map or a stock p28 ecu.
OBD1 to OBD2a ECU Conversion Harness
That is the type of harness you will need to run an obd1 ecu.
you would use the ecu for the head.
Cool I had a good assumption I could keep mine since the head isn't changing. Just needed some assurance from yall more experienced guys!
1 - 4 of 4 Posts
