1 - 1 of 1 Posts
Ok well heres background on it, new tucked harness everythin ran correctly, all grounds where they should be, all plugs in correct spots. No codes at all, i drove car to work an back home with no issues i let car idle an kinda sounded like it was missing, so pulled plugs an all are in good shape an gapped correctly. So i decided to check wires for any arching, car was idling fine for a few minutes then it shut down i was confused an checked fuses, ecu 15amp blew. Replaced an achecked all wiring an fuse wouldnt blow, tried starting an fuse didnt blow but had no spark, so started diagnosing dizzy, igniter was good but coil only showed good from point a to b, but not a to secondary spring. So could the coil goin out have blown the fuse?
1 - 1 of 1 Posts
