61 - 62 of 62 Posts
Thats the one
138019
Grounding pin 8 with the key on should activate your fuel pump, jumping pin 1 to pin 3 will feed power directly to ecu and the sensors, see if it fires that way.
yep, if you found it near the steering coloumn.
As far as wiring replacement, it is going to be smarter to track each wire one at a time and figure out if they are all making it to the ecu and fuse box and sensors.
You would need to verify the dash harness is good anyways with a repalcement, unless you sprung for an expensive NEW harness. These cars are far too old to make any type of assumption!
61 - 62 of 62 Posts
