91 CRX Si
Noticed my CRX has been throwing a code 7 (I think...cant really remember).
Anyhow, it was for throttle position when I looked it up. It will throw it every once in awhile after taking gears 1,2 and 3 to the top (like a 1/4 mile run)and letting off. All I got to do is reset my ECU and it's gone. It may not be back for a while. Any ideas or suggestions? Do I need a new TPS?
91 CRX Si
Discussion Starter · #2 ·
anyone?
It might be miss adjusted, my friend had this same problem only after he went full throttle. I adjusted it using a DMM, and no more problems. You have to test the TPS sensor to be sure that it is good. If you dont know how to check it PM me.
91 CRX Si
Discussion Starter · #4 ·
Thanks
you can remove the throttle body and remove the riviets and put either allen bolts in them or use your imagination. :) just so that you can adjust it manually. 5V at wot and 0 and closed if i remember.
