1 - 14 of 14 Posts
OKay i was told that if ur running boost with ur stock ECU that it will throw a check engine light as soon as it see's boost....some people say u have to get it chipped for it and some say u can just bypass it by rigging up some way......i want the truth on what i need to do to have it correctly and safely done...pretty good price.....hopefully around $100.......so any help guys?
O
missing link.
www.ebay.com and search for missing link. it is a special 1 way valve that sits betweenthe map and the TB to keep it form seeing boost.
you better make DARN sure you have proper fueling or you will blow your motor.
oscarmayer said:
missing link.
LISTEN TO THIS GUY, HE KNOWS WHAT HE'S TALKING ABOUT! AND I CAN'T STRESS HOW MUCH YOU NEED PROPER FUELING AND TUNINIG! I'M TALKING FROM EXPERIENCE!!!!!! GOOD LUCK
Shoot me!
oscarmayer said:
missing link.
Thats it right there pick it up you'll be fine.
yea i was about to say, a check valve would keep the map sensor from seeing boost, i just never understood how it would let air into the hose between the map and valve for times where its no boost, no vaccum
alright i will pick that up.......so i do need to go get it tuned? i have a guy that will chip it and do on the road tuning with his lap top and hondata or uberdata for $200....he said it can make the difference between night and day....
V
you can always build one out of supplies from a fish store, 3 lengths of tube, 3 T shaped bypass valves, place them consecutively b/t the throttle body and athe map sensor, shouldnt cost you more than $10 to make, same exact thing as missing link, i used to have a web page i'll see if i can find it.
ah found it! here:
http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
should be towards the bottom but its there
Lifetime Awesome Member
to do it cheap, you will still have to get an fmu and i believe an fpr. or go with the vafc, which can be found anywhere from $150-$250.
personally, id just get your ecu chipped to accept Uber or Crome, and find someone that knows how to tune
Why do you need this "check valve" if you can have hondata or uber??? The stock map sensor can see up to 10 or 11 psi of boost!!!
O
NO do not let "some guy" do the tuning. you want a shoip with a professionaly reputation for doing good work. I cannot stress how many times i've heard this story only in the end to hear that the motor blew up due to improper tuning. use a shop with a dyno to tune the car. e-manage can me used up to 10psi w/o a problem.
i have a 98 civic and all i did was ran a 6psi turbokit with the missing link, votex 12:1 FMU, no intercooler w/blowoff valve ran fine for the longest time..never had a problem. anything 8-10psi u need at least afc w/450 (missing link not needed) 10+psi uber/crom works great..BUT WHAT EVA WHY U GO GET IT TUNE!!! NO STREET TUNE EITHER BEST BET IS TO HIT A DYNO!!!
well see this is what i got
T-25 Turbo
SSautochrome Manifold
Greddy Type S BOV
Johnny Racing Front Mount Intercooler
DSM 450 injectors
SAFC II Controller
Vortec FMU
on my D16Y8 with a stock P28
1 - 14 of 14 Posts
