1 - 2 of 2 Posts
Hi guys looking for some advice on my setup, stumpted with the mabagement side,
D16y7, 75mm vitara pistons, skunk2alpha series rods, acl bearings, arp2000 bolts, arp rods, td04l turbo (max cfm 390-400) 2.25 exhaust system
Now for the main question, if I use a socketed p28 ecu with a jumper harness and 440cc injectors do they have to be saturated or peak and hold, also do I need a resistor box, the reason im confused is because standard setup is obd2 but the ecu I want to use is obd
Any help would be apprechiated, thanks
1 - 2 of 2 Posts
