1 - 20 of 31 Posts
please don't tell me that is a real "fix" someone attempted.
95 civic coupe
95 civic coupe
it's crazy. I do not use it.
But back to my point. What do you think of my block notch?
Did you actually need notch the block? Check by installing the whole rotating assembly, but if anything just make the notch a little bit wider.
Yes needed the notch, when put together the pieces, beat the cylinders. Now, do not hit nothing but maybe needed a little wider.
95 civic coupe
Here's an example of mine when i did it.
95 civic coupe
1 - 20 of 31 Posts
