1 - 10 of 10 Posts
88 RT4WD wagon
i had the same issue with some p2p0s the other day, had been sitting on my shelf for a few years. some pb blaster soaking for a bit and they broke loose
They are torqued to the value the bolts are supposed to be when installed so they can hone the big end.
Oh well that makes sense then. What's the best way to get them off?
Buy a vise and either buy a rod holder like the proform rod vise or buy a set of aluminum cover jaws so you don't ding up your rods.
Clamp them hard vertically and use a 1/2" size breaker bar with appropriate socket.
88 RT4WD wagon
yep thats what i did after some PB blaster. my little 1/4 adapter one took it off fine so any 1/2" should pop them right off.
1 - 10 of 10 Posts
