1 - 9 of 9 Posts
Hey Guys
I got my E-management tuned on the weekend after driving round on GReddy base line stock tune for 2 months without any problems..
But now after re-tune I'm getting the following red LED error code warring's
D16Z6 + standard GReddy bolt-on kit
4 slow blinks then 8 quick ones then 5 slow blinks then 8 quick ones..
Then it stats again..
Can someone help me out with what they mean?
Thanks Guys
Luke
did you look in your user manuel? the codes should be in the end of it. unfortunatly greddy doesn't have the trouble shooting section online. at least not for error codes, that i could find. did you try to call them already?
Hey 99EJ6T
Calling them from Australia would cost heaps if $$ lol
I've found this
http://www.mohdparts.com/emanage/install/install_help/error_codes/index.html
But what do those errors mean?
No injector CH 4
No injector CH 5
If I'm reading it correctly lol
Thanks for your help
Luke
Hey 99EJ6T
I've found this
No injector CH 4
No injector CH 5
Luke
i see. well you might want to re-check that second code. since it seems the codes only go to 57. accourding to what you have listed, you have codes 48 and 58.
48 being: JP1 pull down error, incorrect jumper settings (jp1).
i would go back to the tuner and have him/her pull the codes while the software is booted up on a computer.
Hey man
Its 4 slow blinks then 7 quick ones then 5 slow blinks then 7 quick ones
What codes dose that relate to?
I don't understand how the Code table works lol
Hey man
slow blinks = 10
fast blinks = 1
your e-management codes are 47 and 57.
i guess your emanagement is not set up correctly. refer to this:
http://www.greddy.com/img/PHP/products/pdf/1286.pdf
^other then that, i don't know. i am not a greddy emanagement owner. GL though :)
Fixed
The tuner hacked into the ignition harness but we don't change the jumpers to suite..
Installed the Honda plug&play and changed the jumpers and all is good :)
No VTec though
Maybe the e-manage rotors need changing but I can't find any real info only her say ..
1 - 9 of 9 Posts
