1 - 20 of 28 Posts
Go-Autoworks.com has excellent radiators at a very reasonable price I have ran one my race car for 2 yrs now and it works flawless. Some of the ebay warehouse rads I have seen leak like a sieve after a couple months.
Formally known as SPONSOREDCRX
Lifetime warrenty fuck it. What do you have to loose?
so whats a good way to get mine cleaned? i think i ate so much oil into the coolant that i gummed up the radiator...
93 Legend L Coupe.
It's generally not worth it. Most of the eBay units are good. I ran one in my 92 Si with no issues at all. Cleaning our a radiator that is seriously gunked up can actually make things worse if you dislodge all the crap into your cooling system.
i figured that...and what i would have paid to clean it i could have bought a new one...
PM answered...
racist-bigot-sexist-homophob
Using a dual core half rad.....works fine.
honda/firebird form.
Only if you don't notice your running hot. Which is really pretty easy to do......
lol i know. you will notice it before you cause any engine damage lol
if you just want to replace the radiator, not looking for performance, read the seller's feedback, and buy it. its just a replacement for the stock radiator...
Discussion Starter #16
yeah...its just a stock replacement...
Step up and get the dual core. I've had both and the all aluminum dual core is constructed much better.
yaeh im running a mishimoto i got off ebay for cheap. no probs at all.
eg9
i've got a 1" single core aluminum with plastic end tabs ebay model and its ran fine for years no leaks. i had the same issue old motor clogged the old radiator with oil and i would prefer the thicker single core over the smaller dual core.
your best bet is the goautoworks though its got aluminum end tabs so it'll last longer and i believe its thicker then the rest for cheap!
Discussion Starter #20
clutchmaster wants to sell me an OEM 5th gen radiator for 38 bucks shipped...
two issues:
1. will a 92-95 radiator fit my 6th gen?
2. i am apprehensive about buying a used radiator...
1 - 20 of 28 Posts
