1 - 14 of 14 Posts
1995 Civic EX Coupe
ok. ive got a 91 HF with a D15B7 swap and Si Tranny. I was using HF axels and hubs with the SI tranny but i had a bad wheel bearing so thought, what the hell, i can get a whole new DX knuckle and axle from a friend for $20. So i put it on and was wondering if im gonna have any braking problems or anything since the DX caliper and rotor is substantially bigger??
TIA,
Bryan
1995 Civic EX Coupe
no. thats what im asking. got an HF on the passenger side and a DX on the driver side. just wantin to know if it would be ok. now that i look at it, it looks like the rotor is the same size but the caliper on the DX is bigger. can/should i just switch the caliper to a DX one on the pass side?
1988 CRX HF
Im not 100% sure but i think the ex, dx and si are the same and the hf and standard are the same. I wouldnt risk it, you could go to the junkyard and pull a knuckle off the pass. side of any civic ex, si or dx and have everything the same, prolly for the same price as a new dx caliper would cost. the DX caliper may work im not sure. i have the passenger side knuckle (with all braking components) on a dx sitting in my back yard. PM me about it.
bwah ha ha ha ha
CRX
Ii would switch the pass cuz the driver side will prob pull harder now that it has a bigger caliper
1988 CRX HF
wam-crx,
i dunno if this is off topic or not, but could you put dx rotors and calipers on HF knuckles?
This would be a good oppurtunity to swap to acura integra ls knuckles/brakes :) . I did the swap a few months back and it has probably been the best money i've spent on my car.
1995 Civic EX Coupe
Discussion Starter · #10 ·
yea i was thinkin about it but heh. I only need something to get by for now.
wam-crx,
i have not tried that. so i do not know but i think it would work. there is only ?.100 diff between the HF and DX. not much of a upgrade. if that is what you are thinking. not worth the time it would take
1995 Civic EX Coupe
Discussion Starter · #13 ·
i already know that as i mentioned it in the first post.... its up and runnin thx.
put the DX brakes on the other side, knuckles are the same, just the caliper bracket and rotor are different I believe.
The caliper should be the same.
1 - 14 of 14 Posts
