i think open dump sounds mean as all hell. i like it, and im running open DP so it wont really matter too much. i just want to make sure that the gasses wont effect power outputwont hurt it but i would get it made longer or re-route it into the exhaust so it doesnt sound like shit.
that whould work very well. especially if you give it a few tac welds for structural integrity. trust me, youll still hear the wastegate open. some people think it even sounds louder because it resonates off of the ground.so i should just extend the tube to run down beside the dp? would that work?
uh...YES it will...wont hurt
lol ok. ive had ones way shorter than that before....uh...YES it will...
route it under the oilpan to make sure no gasses get sucked into the turbo
and yea if youre already running open downpipe then you'll be ok.i think open dump sounds mean as all hell. i like it, and im running open DP so it wont really matter too much. i just want to make sure that the gasses wont effect power output
thanks for the comment :TU:
the heat coming off a dump tube that short would kill your power levels. i think it was jeff evans who gained 85 whp by rerouting his dumptubeand yea if youre already running open downpipe then you'll be ok.
it doesnt mean your not murdering your power. at first i thought mine would be fine running no dump at all; boy was i wrong. running your dump in the engine bay can also over heat your turbo causing things to break, in my case the compressor backing plate.lol ok. ive had ones way shorter than that before....
Are you not reading what has been said? Were are you getting your information?no it wont effect it but you will want to make it longer and make sure it goes down and not itno the engine bay
