1 - 13 of 13 Posts
milano red ej8
hey guys,i have tried searching this everywhere but couldnt find any info on this anywhere.
Ok so i have 97 coupe and i am trying to wire in the resistorsto run my dsm's. And as you all know the dead end plug is under the intake mani. So what i wanted to do is wire them in right up by the injector clip(a few inches away tho). So im just curious if that would work or do i have toget them by the dead end plug?
Thanks in advance guys. and all input is welcome.
milano red ej8
that would be great if i was gonna use a resistor box. i just want to use theindividual resistors from radio shack. I have searched a lot on this, thanks tho man
Anyone else?
hey , yeah they will work fine right at the injector plug! this is how i have mine wired
I had the same problem, d16y8; dead end plug under the mani, and its like bolted in under there, haha no thanks!!.
milano red ej8
ok cool thanks man. i have searched all over but i havent found anyone that wired them that way i just wanted to make sure it would work.
sure thing man! my suggestion would be to strip the wire as FAR away from the injector as you can, i didnt pay particular attention to this, and now it looks kinda messy =/ oh well ill redo it when I pull the motor in a couple weeks. also be sure to solder solder solder!!! very important you have good connections, this aint no underglow kit! hahah
milano red ej8
ha ha for sure man. thanks for the help tho man.
Anyone else run their resistors like this?
Quite a few people actually. Solder and shrink wrap are your friend.
I have also seen a guy make a plug and play type. He used a resistor bob but same thing could be done with individual resistors. He soldered the wires to a plug that plugged in where the dead end plug went. No need to cut the factory harness that way.
milano red ej8
thanks for the help guys, i just said forget it with the rad shack resistors. i got a box from the local yard for 15 bucks and i made a pnp harness for it.
1 - 13 of 13 Posts
