1 - 18 of 18 Posts
Ok I not its a dumb question but its to late to fix it right now so I wanna ask ok I have a crx d16a6 running a garret t3 t4 and a few bolt ons but I just got the dsm 450 blue top injector and I just got my pm6 back for xwnocron today which has a base map to run the turbo and the dsm. Ok so I was running the stock ecu and injectors it ran fine I mean I wasn't really driving it but the littie I did it was fine but when I put the ecu in and the injectors there was a rubber o ring that went around the injector where they went in to the intake manifold about the size of ur pinky well the dsms are bigger so I took the o rings out the dsms fit to the 10 mms ont the fuel rail fit now I went to crank it and it didn't leak fuel or anything but from the crank up it shot to like 5k rpms now I had a intake manifold bad gasket and it did that before so when I took the o rings out is that y and if I fix it will it be back to fine and does anyone no how u make the o rings fit the dsms right? Sry for the quest
^^^^hahaha. This is true it is hard to read. Are you talking about the o ring on top the injector? Or the o ring the presses into the intake manifold?
I got 1/4 the way through and gave up.
If you want to re-post a clear and concise question, preferably in point form with some punctuation and space, I will read it and comment if I have anything to offer.
If you can't be bothered, neither can I.
Sry guys I typed it real quick but yes I was talking about the o rings that are pressed into the intake manifold not the little ones the that go thro the fuel rail thanks
Do a quick search on google. You only need 1 tool to modify the big rubber o ring so the injector fits nice and snug.
Hes trying to tell us something i can feel it!
I do believe is timmy suck in the well? The house on fire? Lol
Really op use some "." And "," it only takes a sec. And then people can understand u better. But you drill out the stock honda injector orings.
hey brother, use periods and things. It helps break up the sentences.. holy jeez that was hard to read.
just use civic orings and put a tiny coat of grease aroudn the base of the dsm inj where it meets the seal, itll slip in as u tighten the rail and no leaks
1 - 18 of 18 Posts
