1 - 19 of 19 Posts
I am currently running 560cc evo 8 injectors in my setup. I am upgrading to Precision 780cc injectors(for a little more cushion room). The insulators are pretty rough, so I wanted to replace them. What size do I need? I am running a skunk2 intake manifold, if that makes any difference? Anyone know? I just want to make sure I am good to go for tune date in a few weeks here....
Insulator?
You mean the one rings?
If so the normal honda ones work just have to drill them out some.
yeah the O-rings... Oem will work? Hmm Drill them out to fit the injector? or to fit in the intake manifold properly?
My civic
stock orings, dremel and a sanding drum.... about 10 seconds per oring.
ej8
its just a light sanding on the inside correct.... because the dsm injector is a little wider?
Yes. Just a few seconds on the inside then test fit. It's OK to fit tight, just lube them up and slide the injectors in.
2000 Tundra
Is there anything wrong with just cramming them in the stock o-rings? They were a little snug for me but nothing extreme.
this something you can get just about anywhere?
The only place I know for sure to get it locally is Grainger. You can also order it online.
You just don't want to drag and tear the o-ring or stretch it past the point that it will return to it's desired size that's all. Realistically you could use about anything that was a lubricant as long as it isn't damaging to the o-ring material....soap, spit, etc. Engine oil should work too.
The reason I used it was because after I sanded out the inside of the injector seal to fit my EVO injectors they were still a little too tight for my liking, but I needed to get the job done so I could get on the dyno. So instead of sanding them more, I just threw some lube on and stuffed 'em in. No problems yet.
well I went to mod the oem injector lower seals and they fit snug without any modding? Its weird because I figured they would need a little bit of sanding... They are the evo version of the precision 780ccs... Maybe the factory dsm injectors have a slightly larger base than aftermarket injectors do.... either way I think Ill be good!
del Sol si '94
Never tried those, only used the 450's. The insulator/orings needed modded in my application.
Just about any lube will work, I use silicone spray or grease, whatever is handy. No need to go out of the way to get a specific type.
Just use the Dremel as stated, sand a lil and check fit. Youll have to hold the O ring in your fingers, use some snug fitting rubber gloves. May save some skin lol
Discussion Starter #16
I am more concerned about the injector fitting in on the car, so I might have to sand them down. I am still not sure until I attempt to swap injectors. But worst case it wont be bad... Ill keep posted with the results...
2000 Tundra
Yep that's what I did on my 450cc's. Went in like butter. The first time I installed them I dremeled the seals and ended up taking them too far. I ran rtv between my injectors and seals for years like that. This time I didn't bother and just put the seals in the intake and then injectors in the seals.
Discussion Starter #19
Snug fit without modding them. I prolly could've trimmed them up a little bit. But with some super lube injector lube they went on very snug and NO LEAKS. Perfect.
1 - 19 of 19 Posts
