1 - 13 of 13 Posts
formerly Kit88
Hi guys I need to know if I´m gonna need bigger injectors,
Turbo Apexi kit with 440 dsm injectors runing 15 psi of boost, somebody told me that I must run bigger injectos if I´m gonna run more than 12-14 psi of boost.
My car is doing 219 whp and 213 tq but looks like is so lean, could be the injectors or just the map.
My friend runs about 231 hp on his RC 440s...no signs of a lean condition. I don't think "psi" has much to do with the calculation, but I could be wrong...
formerly Kit88
Thanks bro, any idea how much hp´s could handle the 440cc´s??
I think that exist a way to calculate but I can´t find it.
racist-bigot-sexist-homophob
formerly Kit88
insert user title here
i think evosol did around 320 hp on his 450 cc injectors. but he was on water/meth injection so that was kinda pushing it.
formerly Kit88
Thanks guys , I think I´m gonna keep my 440´s
well, why dont you look at your datalog and see what the a/f is and see if the injectors are maxed out...and see if the fuel pressure is correct...
if you are lean, and the injectors are maxed, then sounds like you need to check your fuel system...
When Eric tuned my car, the 450s were running at 35% duty cycle under full throttle/load so id say that 300hp as stated above sounds about right since you want to run injectors at about 75-80% duty cycle max to keep the setup reliable.
1 - 13 of 13 Posts
