1 - 7 of 7 Posts
CRX ECODiesel Ram
Since I have had my crx i have done a lot of work over time to refurbish it. It sat for about 5 years before i got it.
The brakes at the time were rusted, so just to get it running i replaced pads and rotors. a year later the front right rotor was nearly black colored and warped. I had the rotors replaced under warranty, and rebuilt the calipers. 18 months later the warping was back along with a lot less discoloration. I bought new rotors and new ceramic pads, also replaced the front brake hoses with new aftermarket rubber ones. I also regreased the pins the calipers slide on.
I have noticed more dusting on the front right corner which makes me suspect the pads are still dragging slightly more than they should.
Other things I have done that may make a difference....i replaced both front wheel bearings at some point, did a rear disc conversion and replaced the master cylinder and prop valve (the warping occurred before and after all this). During the rebuild I painted the calipers as well.
The only brake part that has not been touched is the hardlines under the hood.
What else could be a cause? I am a bit baffled, everything did need to be replaced due to age and wear but either something else is left I missed or is it possible a wheel bearing issue on that side?
Its possible that caliper is still having a problem. I went through 2 "rebuilt" calipers on a car before I got one that would no longer seize.
Now this could also possibly be attributed to a blockage in the line that was flushed out when the 3rd caliper was installed but I doubt this highly.
Sounds like something is still wrong with one of the calipers. Have you tried buying new/re manufactured calipers?
CRX ECODiesel Ram
The parts that were not replaced when i rebuilt the calipers were the guide pin boots and the piston itself. Thinking about it when i removed the caliper on the passenger side to replace the pads, hoses and discs last week it was difficult to push the piston back in (with no hose or pressure on it) compared to the driver side. Possibly a piston that is out of spec after 290k miles and 26 years? Either way it was nearly $30 for a new piston, so i went ahead and ordered a reman caliper from Rockauto hopefully this will make me happy, i know it won't cause an immediate problem but i hate re-doing brakes every 12-15 months for something this simple.
CRX ECODiesel Ram
When i rebuilt them there was not any visible scoring or anything that would lead me to suspect a problem, however that was also over a year ago, and the first time in over 10 years that i had rebuilt any brake system parts. I could easily have overlooked slight wear that didn't just jump out at me. It could even be something as stupid as the seal inside the bore being slightly messed up from my re-assembly. I can say there was a lot of crud inside the caliper when i tore them down, reddish black and built up. If I did not drive the car almost every day I would go ahead and tear it apart now to see...but the $28 for a reman caliper is cheap enough i al just going to swap it and take the old one apart when i have more time.
CRX ECODiesel Ram
So Fedex picked up the caliper from Sugarland, TX (on the SW side of houston) and should have been able to ship to Conore, TX (just north of houston) in one day. Only problem is it got sent to Dallas and then to Maryland. Contacted Roackauto and Fedex. Rockauto said it will get there tomorrow, its still in Texas, and they also told me i should have done overnight shipping if I wanted a guarantee...except I just wanted reasonable shipping time since it was only 60 miles away. Fedex said they don't know if they what they are doing. BTW the order was placed Wednesday and was supposed to be delivered yesterday.
Anyway, now tracking says in Maryland for delivery in Conroe next Wednesday. SO I call Fedex and request to reject the shipment and have it returned and I email Rockauto to let them know its going back to them and they owe me a refund of the part AND shipping. Last time I ordered from them their catalog was wrong and they sent a part that would not even fit a Honda....
lets just say I am going to stick with Advance Auto Parts from now on. Rockauto blew me off and thats it for them.
on a side note i took apart the caliper today and found some rough/rusty patches just below the line that shows where the seal sat. lightly sanded the piston and caliper bore and re-assembled...we shall see!
1 - 7 of 7 Posts
