1 - 4 of 4 Posts
Hello everyone, I have been reading and researching and either I'm blind or I'm not seeing what I'm looking for.
Basically I have 90' Civic Hatch DX with Dpfi Fuel injection.:bsflag:
I am wanting to convert to MPFI. The reading I have done says you need basically 89-91 Si everything. Intake Mani, Harness, Injectors, Distrib, ect....
My question is: Does any of the basic requirements change if I want to use a D16Z6 Intake manifold?
I ask because I have a D16Z6 intake laying around. From what I understand, it would be one of the best intake manifolds to use.
Thanks in advance for help.
No. I think the tps wiring is reversed on the z6 mani, but I might be wrong. FYI - You can also use a HF distributor.
the z6 intake will work just fine the only thing u need to adjust is you need to use a Z6 fuel rail and fuel pressure regulator.
the a6 regulator doesnt bolt to the z6 fuel rail and the a6 fuel rail doesnt bolt to the z6 IM
1971 VW Super Beetle
tps wiring is reversed mpfi and dpfi in general not specifically between generations.
Hit up sleepingciv his conversion harnesses make the wiring painless!
1 - 4 of 4 Posts
