1 - 4 of 4 Posts
J
ok i have an 88 hatch std and im swapping in a d15b (im stickin with obd0 tho)...i just need to know what else im going to need...even little things...i dont want to be unprepared when i go to do the swap....even the little things guys...
I have:
-D15b motor
-88 Si tranny
-88 Si clutch kit
-Resistor box
-obd0 injectors and distributor
-89 Teg ECU
-header
-complete 91 si engine harness
-Vtec controller
what else am i going to need?
thanks....jawz
'91 CRX Si
si throttle cable, buy new from dealer unless you can get it cheaper than 20bucks, IM gasket, tb gasket, a new "u"bend coolant hose, goes from thermostat to IM.....any nuts that look like they could be replaced
might as well go ahead and replace injector o rings and seals, fuel filter, random vaccum and coolant hoses, that is if your not crunched for cash
J
do i definitly need the si throttle cable tho? ...the stock one in my car won't work? I thought it was just too long but it will still work?
1 - 4 of 4 Posts
