1 - 13 of 13 Posts
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
it says the si wiring harness will be much harder to use...does this mean i dont have to get the si wiring harness? if so how would i connect the wires to the injectors without the extra plugs that attach to the injectors?
'06 GMC Sierra Crew
Pick up a complete Si engine harness. You will use more than just the injector plugs off it. It will make the job MUCH easier.
91 civic dx sedan
so he needs the engine wiring harness correct????
'06 GMC Sierra Crew
if u get the Si harness, why not just get the ECU side, install and b done with it?
The ECU side is part of the main harness. So you'd need to swap over the Si main harness too. Needless to say it would be a HUGE PITA. I briefly thought about since my interior is gutted with no dash etc. and still decided against it. I cant even imagine thinking of doing that with a full interior.
thats why im going doing it the ghetto way
The H Badge is it!
91 crx
when i did, was i went to the junkyard with a 10 dollar bill, flat head screwdriver and a 10mm wrench. grabbed a resistor box, injector plugs and a random plug with 4 wires on each side, and the distributor plugs.
the 4 wires u need to lead from ecu (a3 and a7 i think?? and c1 and c2) both go into the random plug, then the 2 A wires to proper injectors, and the C wires to the distributor... as for the big distributor plug, i just depinned the stock one, and repinned them into the big one.
any questions PM me.....
Just curious on how many wires are linked to the main harness... it can't be more than 6-10... but I see your point.
94 G20
im about to do mine, but im using a boomslang obd0 to obd1 mpfi harness so i just need the injector plugs. But getting the si harness will deffinatley help you out.
1 - 13 of 13 Posts
