1 - 2 of 2 Posts
95 ej2
I felt the noob forum was A good place to put this because even though I cant seem to find any info on the subject I know there must be by now at least 1,000 people that have done this.
Converting my 91 DX civic hatchback to MPFI and obd1 at the same time. My problem is im trying to make my own dizzy jumper harnss following this write up:http://www.d-series.org/forums/diy-forum/57665-diy-make-your-own-obd0-obd1-distributor-adapters.html
My problem is I do not have the big round plug like on the SI's I have the small square plug with 5 wires instead of 7. My question is simply how can I make A jumper or any fairly simple way to wire this.
Using b7 dizzy chipped p28 ecu y7 block and head
If I remember right you need to run two wires from the distributor plug to the ecu plug. Pic below should help.
1 - 2 of 2 Posts
