1 - 3 of 3 Posts
ef hatchback
hey guys,
lemme hear some opionions on going obd1 from obd0. Im also converting to mpfi.
I already have rywire ecu/dizzy jumper harness. but for parts I have obd0 dizzy and ecu (its dpfi so I gotta buy a new ecu regardless, but)
should I buy a pm6 ecu and obd0 mpfi a6 dizzy? and plug and play the b7? (plus the resistor wiring and fuel injection wiring?)
thanks for your help/opinions.
(been reading a ton of posts for a few years, this is my first post)
\/Your Mom Was Here\/
Vibe GT
You can run odb0 on a d15b7 motor. ForeverDeath covered that part.
For injectors you can use the obd0 ones and a resistor box or odb1 injectors and bypass the resistor box. Which ever is easier for you.
1 - 3 of 3 Posts
