1 - 4 of 4 Posts
EK 96
Need help the driver side door wont open the mechanism on the door and rear panel don't work the metal shafts that goes from the door handle and the inner handle. Can someone help to open the door from the inside so I can fix it.
ministry of mayhem!
93 honda integra
damn man, maybe after work i can go to your place or you can come home and i can help you fix it... you got my number.
EK 96
I can call you I am out at 4 o clock .I will need to buy that piece new the one thats makes the door lock.
you said the inner handle is not hooked up? cause thats prob all it is.....the little clip itn there like to break....just use a zip tie to hold it on...hard to explain but youll see when you get it opened up......will the door open from the outside?
1 - 4 of 4 Posts
