well I have the actuator installed and tested it. And it works fine. have the wire routed into the car. The problem is that with the door panel on it seems to push into the interior door handle rod so when I open the door it the handle stays open. was just curious if someone had a good location. Or if it was going to be a little while between adjusting and putting the door panel back on till I get it working fine.
