1 - 20 of 27 Posts
y7 Block, .20 over Vitara/Eagle Setup
y8 head
13,000 miles
Cylinder #1 - 140
Cylinder #2 - 135
Cylinder #3 - 140
Cylinder #4 - 140
Testing before I buy more turbo parts
My tuner/mechanic said it was perfect!
What's your guys numbers? ptw clearance .0035
and just for laughs, done a test on my built gx200 go kart.
it was 150 lol
It's got 12:5:1 compression ratio :D, it's a rocket
i got 270psi on all 4.. built about 1 1/2 years ago..
on a vitara build???????????
i've never heard of anything that high
your clearances must have been tighter than a nuns pussy
your ptw clearance shouldnt have anything to do with the comp ratio... but 150 is where my vitaras are at right now
Well?
What diesel was this on?
plenty of all motor cars see 300+ psi of compression.
OP- numbers sound pretty good to me. mot vitaras are from 140-160 from what i've seen
really? I havent seen them that high on anything, Guess i learn something new today. What cars have that much compression?
The highest i've saw was a 11:5:1 compression V8 and it was like 260.
It scared me at first and my tuner/mechanic said it was perfect
Well?
depending on the setup some mildly built b's will see 260-270 with about 11.5-12:1 CR. Higher than that and you will start flirting with 300 but it depends on a lot of things
Discussion Starter #16
my fjt/vitara z6 bored to 75.5mm put down 180 across all 4.
I guess the longer rods had a factor in that, i'm running eagles
i pegged my schools 280 psi snap on compression gauge. Im sure i had atleast 300 psi 13.2:1 is ALOT of compression. funny to see that thing roll all the way over and peg everyone in my class couldnt belive it.
racist-bigot-sexist-homophob
Discussion Starter #20
.0035 PTW? too tight for my liking, especially for a cast piston.
imho, vitaras need at least .006 if you plan to make decent power.
I let my very reputable mechanic decide this, Vitara/Builds accounts for about 60% of his business, not dissing you or anything i'm just saying thats why it is the way it is.
My goals are 300 WHP
1 - 20 of 27 Posts
