1 - 20 of 63 Posts
hey guys im new to the site and the name says it all im a domestic guy thats built nothing but big HP cheverolets v8s FTW! .....but ive decided to build a honda underdog so i bought a 91 civic ex hatch and i bought a few Dseries engines ill post pics soon but here is the engine.
block
d15 stock bore
crank eagle 4340 forged crank
rods eagle 4340 h-beam rods
SRP 9-1 turbo pistons pressure releif drilled
stock oil pump
stock water pump
moroso oil pan
cometic head gasket
d16z6 head ported and polished with .5mm skunk2 oversized intake valves
skunk2 stage 2 turbo camshaft
skunk2 valve springs, retainers and locks
type r 3 angle valve job
full race turbo manifold
garret t3/t4 hybrid turbo
tial 36mm wastegate
70 mm throttle body
RCI 420 cc fuel injectors
lonewolf fuel rail
B&M fuel pressure regulator
hks bov
y8 intake manifold
msd sci ignition box
msd external coil
msd cap adapter for external coil
the engine is planned for hitting dyno in two weeks the engine isnt togeather yet but should button up fine ive built this project off of domestic knowledge and dedicated research let me know what you guys think and like i said pics will be up soon it seems to be uncommon to reach 500whp but i plan on doing so lemme hear what you think.
Reactions: Import Al
Your gonna need bigger injectors then 420's if you plan on making 500hp, also a 70mm tb on a y8 itm wont really work unless it is getting ported which will be kinda big!!!
Honda
for 500whp, you may want to look into sleeves..............just a thought though. Im sure the stock sleeves will support it for a while if the tune is good, but i wouldnt imagine them holding for long.
I would also look into upgrading/modifying the oil pump so you get plenty of flow and not throw a rod bearing.............www.theoldone.com has a diy on how to mod it yourself, and you seem pretty knowledgable so im sure you wont have any problem with it.
I didnt see anything about a higher output fuel pump either, and with the power you plan to make, that is almost a must!!
And lastly, i dont see ANYTHING about tuning. This is what will make or break your setup so i HIGHLY reccomend that you do lots of research on it and find someone locally (unless you know how to do it) that is an excellent tuner. You are going for a very high hp goal and you will need to find someone capable of tuning it comfortably. Look into hondata, crome, crome pro, and uberdata. the order i reccomend them are hondata, crome pro, crome, and uberdata. The only catch with hondata is it is $400 with boost option. Crome pro is $150, and the other 2 are free.
Oh yeah, one last thing, your injectors are WAY to small. they will max out at about 250-280 whp i would imagine. for 500hp i would look into some 1000cc's...............
And i have only seen one d-series do over 500whp, and it can be located at www.turbod16.com
i bought two sets the others are 550s and i designed a tapered adapter for the throttle body to increase intake velocity for lower rpms so it should wrap a little faster to decrease in turbo lag and im sure the biggest part of this battle will be getting the fuel map and timing curve figured out but the AEM ems that i just ordered should be a little more user freindly, its also getting methanol injected to keep intake temps down and and increase spool.
Discussion Starter · #8 ·
the problem with the oil pump is if you notice the companys ive bought from are kind of generic the only reason i went with the eagle is because i have a turbocharged 78 malibu that makes 1400 whp its fuel injected with bigstuff 3 ems the companys ive chosen are somewhat new to imports but pioneers of domestic HP and ive struggled to find a aftermarket oil pump, the fuel pump is a whallbro 255gph but im not sure if it support anything over 500cc injectors
Discussion Starter · #9 ·
exactly why i gave in, i dont know everything and despite what some say an engine isnt just a engine they are all different and who better to come to then people who build them everyday?
Honda
what are the specs on the t3/t4. it better be a big mother to get you the 500whp efficently................
the aem ems will be perfect for management. The 550's still arent big enough for 500whp, they are good to around 350whp give or take......
you are running a ported head, so that will help alot with the lag, i dunno about the tapered TB though , ive never heard of it being effective enugh to noticably decrease lag. Try running open DP or a 3" exhaust (or even bigger if you can get it to fit). that should also help decrease lag time.
methanol injection will be a must if you run on pump gas for that amount of power. If you have never tuned before, i would reccomend finding someone to do it for you, especially with the numbers you are looking for. To get 500whp, you will have to have a very effective/efficent tune that will make the absolute most out of what you have. Thats just a reccomendation though. If you feel comfortabel doing the tuning yourself, then by all measn go for it. :TU:
Honda
the 255lph (you said gph, are you sure its rated in gallons?) should be big enough, but you will need a high pressure pump. Im not sure which you have, but you will def. need the high pressure unit with an adjustable fpr.
Discussion Starter · #14 ·
gladly, and the car may not be an EX.....it was just a fuel efficient turd that i bought from some kid in kansas but pics of my baby i can do right now ill post some pics of it from last season with the blower motor wich still made 1, 134 whp @ 18psi and 879 wheel rated torqe. wich was good enough to push the car to a streetable [email protected]
Honda
post it in the showcase section so we can keep this thread open to help you out............Im sure you will get more posts about your beastly malibu than about your d-series build, so you might wanna just post a new thread for it in the showcase section.
Discussion Starter · #17 ·
<a href="http://photobucket.com/" target="_blank"><img src="http://i95.photobucket.com/albums/l160/raceimpalla/malibu-1.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i95.photobucket.com/albums/l160/raceimpalla/greatbendrace.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i95.photobucket.com/albums/l160/raceimpalla/racingpicture.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i95.photobucket.com/albums/l160/raceimpalla/blowermotor.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
the first pic of it in the building stages of the blower motor, the rest are low in quality but making passes at KCIR with a 10.5 slick if you want i have some pics of my daily driven 10 sec sleeper truck on the bottle.
Discussion Starter · #18 ·
wow that didnt work out so well what the hell just happened?
Honda
you need to use the url link instead of the html tag from photobucket................
when you post click on the insert image button and copy/paste the url.
1 - 20 of 63 Posts
