1 - 7 of 7 Posts
Honda
Which piston is do i need to use for turbo on my z6?
i am about to order from rs machines, and i see that they offer 3 types of arias pistons and i need to know which one to order?
i want 9:1 compression with std 75mm bore, if that matters.
thanks
The Master Fabricator
Dish is what you need... IIRC, a 9cc dish gave approximately 9:1 comp (SRP's), and 4cc dish gave 9.6:1 comp (Some custom Wiseco's I used to have), and flat tops yeild about 10:1 comp (Right now I have flat tops with a Z6 head and I get between 220 and 230psi of compression.)
1 - 7 of 7 Posts
