1 - 17 of 17 Posts
I survived code 9
1998 Honda Civic DX
It's little problems like this that pisses me off!
It won't work no matter which way the switch is positioned. I tried putting a new bulb in and nothing...
Does this have it's own fuse or what? What else wouldn't work if it was the fuse out?
It had some trouble flickering for a while, but got okay.
I tried tapping it lightly and that didn't work.
Any help with this would be greatly appreciated...it's little issues like this that piss me off.
peterbilt
same thing happened to me i hit it and it comes on but goes off when it wants to make sure the wires are in good shape/ connected or it could be a fuse.
I survived code 9
1998 Honda Civic DX
I just beat the shit out of it and it started working.
For a while anyway. It'll probably go out soon.
The bulb is fine. Got power through the connector. The switch is just worn the hell out.
96 Civic HX
do you have a sunroof? does it leak? you might have some rust on the connection on the switch or a bad ground??? just throwing some ideas out there. pull it down and check it out and look at the switch for some possible build up too?.
I survived code 9
1998 Honda Civic DX
no sunroof here.
had a look at the switch and the connectors that run across the switch were pretty worn out. they had a dark line across them and I think that was causing an issue.
still didn't work after I cleaned them. beating the shit out of it worked though.
I survived code 9
1998 Honda Civic DX
How can I check the ground/pin issue? I'm not exactly sure what you mean by that.
The only ground I'm aware of is where it bolts to the roof with the screw.
well.. if it doesnt work in any position, its definitely a power issue. id say the switch is just worn the hell out like you said..
FAMILY MEMBER #316
check the pin switch. when you press in, there should be ground on the dome light wire. when the doors open, it should show 12v. make sure there is continuity to ground when pressed in and that the reference ground (bolts holding switch in) is good too.
1 - 17 of 17 Posts
