1 - 11 of 11 Posts
Well I have aquired a full freakin roll of aircraft quality pre-pregged carbon fiber (31yards L X 70in W). Yes the good stuff. Its looks like a dead body in my freezer and I have no room for my frozen pizzas. hehe anyway I am looking to fab some goodies for my EF, but I dont have anywhere to cook it. Does anyone know where there is a walkin oven or somewhere I can make my prototypes? Since the cf is prepregged with resin, I need to bake it @ about 350-450 for about an hour. Any help would be greatfull. I want to mold door skins and clear out the back seats. A nice carbon fiber dash would look cool with some cutouts for guages. The CF retails over $4000.00 bucks. Thank gowd I know some peeps in the aircraft worlds. favors for favors. :)
how about professional paint shops? not maaco but the expensive ones. They bake your car's shell to cure the paints. VERY big ovens...
paint ovens are not the same. They use lights to bake the paint. I would need a gas oven, like the one at home but in a large scale. something like a keln for pottery.
D
los angeles air force base, there sheet metal shop has a big oven in there to cure fiberglass and such. or use a heat lamp and thermocouples to monitor the temperature. your friends in the aircraft business, they dont have an oven for you?
those guys relocated, not worth a 3 hour drive to cure carbon fiber. I was hoping to find something local. I'll end up fabricating an oven I guess. I didnt want to, Im still looking for an oven to use but worst case is to fab one I could. Heat lamps wont disperce the heat good enough to cure it correctly. That would be good for a small plug though. ARG!!
D
yes, heat lamps can.... thats my job, and it works. just use thermocouples to monitor the heat. you want to place about 5 of them all around to monitor the temperature evenly. for small stuff, you could also use heat blankets and monitor them again with the thermocouples..
thats interesting. I'll have to try that. what kind of heat lamps wattage/volts? I need to bake it at about 350-400.
1 - 11 of 11 Posts
