I installed a DOHC ZC tranny on my SOHC civic EF. I installed it using 89 integra axles. The tranny works fine but around 2500 and 3500 rpm my car starts to vibrate really loud. It feels like its vibrating from the passenger side axle. I know there is someone out there that has done this settup. Can you lead me in the right direction for axles? I heard you can use 90-93 integra axles?
havent you seen my MOVIES?
CR-X
sound like just a bad axle... you can use 93 teg axles but you have to run the half-shaft also
The axle that I used on the passenger is brand new, and the driver side is a custum axle that fit perfectly. I struggled to put the passenger side in. I have a 90-93 axle laying around. I'm going to try it out thanx.
