I have a obd1 dohc zc I am geting a code 8 top dead center sensor so I figured I would check timing first the 2 marks on the inside of the gears are lined up and flush with the top of the head and the outer ones are sticking up is this corect?
B-series Destroyer
4g 4d civic
Pop valve cover off.
Stick pins in the holes.
Reset bottom end to top dead center.
Replace timing belt.
1996 Civic Type DX
Using pins or even the OEM tools to hold the cams can still yield bad timing. I use a LED flashlight and shine it through the holes and line the cams up visually.
had so troubles with timing before, inner marks is want you want to align, UP marks will be off inside a little. how bad a timing should be to get TDC cel? if the cel is random - probably bad harness, sensor to rotor gap too big with dizzy bearing loose, dizzy seal leaking a lot of oil, or a bad sensor if you're getting it all the time.
I had a weird issue with cyp sensor - the contacts in harness to ECU connector were corroded 0_o
