QUESTION... Are the obd0 and obd1 timing belt covers the same? reason i have a 0bd1 dohc zc and i am puting it into a 91 civic hatch the inner timing belt cover was broke so i purchased one from a obd0 dohc zc i have not yet revived it yet. But was thinking huh maybe there different...
maybe i can bolt up the obd0 covers to my obd1 engine (inner and outer bottom and use my upper cover as i still have a good upper)
plus i had to change the mount for the 91 civic
any help would be awesome
90 crx si/96 accord
I'll bet money there the same.
There really wasn't a lot changed from the obd 0 vs 1
They elimated the sensor on the exhaust cam, changed the bolt pattern for the throttle body, different fuel rail, map sensor on the intake/t.b.....couple other things..
Who else wants to chime in?
Ok do you know where I can find a inner cover for one of these engines I recived a email after I ordered it saying they have non left in stock (used parts) all I want is the inner cover for the bottom meets half way on the block and head and the part that surrounds the motor mount I have everything else holy F**k what a quest to find any ideas even if some one has one I will buy it...
