161 - 180 of 188 Posts
Sort of back on topic... interchange info for the d16a1:
(Obx lsd Part #LSD9000). Fits ALL 1990 to 2001 Acura Integra 1.8L DOHC non-VTEC, 99-00 Honda Civic DOHC VTEC Si and 1992 to 1993 Acura Integra 1.7L DOHC VTEC GSR
This will bolt into the d16a1 tranny. Just need to grind a very small amount out of a rib inside the tranny case
The obd1 dohc zc intake manifold bolts to any dohc zc or d16a1 motor, and allows the use of obd1-2 honda /Acura throttle body's. Example.. You can easily put a b18 60mm tb on, which also allows you to relocate the map sensor from the firewall to the top of the tb
This info may or may not be useful
Okay so I have a d16a8 that I want to put in my 1998 honda civic ek. It's a obd1 motor and I have a obd 2 wire harness in my ek. I had a d16y8 in my civic I need to know if the trenny will bolt up, if I can use the same motor mounts , and how to wire my cam positioning sensor. I think it's called a cam positions sensor it's right next to my dizzy. Help
Retired From Hondas
Why is it the 1st thing a noob learns is the wrong classification of his car?
Pisses me off so much that i had to bump his post
