DOHC ZC Parts Interchange List
Camshaft Seals – 88-89 Integra - 91203-PG6-013
Exhaust Manifold Gasket – 88-89 Integra – 18110-PG6-003
Intake Manifold Gasket – 88-89 Integra – 17105-PG6-S00
Oil Pan Gasket – 88-89 Integra – 11251-P01-004
Head Gasket – 88-89 Integra – 12251-PM7-003
Valve Cover Gasket – 88-89 Integra – 12341-PM7-000 and 12342-PG6-000
Timing Belt – 88 Prelude 2.0 Si – 14400-PK2-004
Timing Belt Tensioner – 88-91 CRX Si – 14510-PM7-004
Timing Belt Tensioner Spring – 88-91 CRX Si – 14516-PM3-010
Front Main Crankshaft Seal – 88-91 CRX Si -91212-PE0-662
Rear Main Crankshaft Seal – 88-91 CRX Si -91214-PH1-661
Water Pump – 88-91 CRX Si – 19200-P01-004
Water Pump Gasket – 88-91 CRX Si 19222-PG6-000
Thermostat – 88-91 CRX Si
Upper Radiator Hose – 88-89 Integra
Lower Radiator Hose – 88-91 CRX Si
Spark Plug Wires – 88-89 Integra – 32722-PG7-A01
Distributor – 88-89 Integra – TD-03U
Distributor Cap – 88-89 Integra – 30102-PM7-305
Distributor Rotor – 88-89 Integra – 30103-PM5-A05
Spark Plugs – NGK BCPR6E-11
Throttle Body – 88-91 CRX Si or 88-89 Integra
Crankshaft – 88-91 CRX Si
Connecting Rods – 88-91 CRX Si or 88-89 Integra
Flywheel – 88-91 CRX Si (use 90-91 unless you have 88 transmission)
Intake Manifold – only DOHC ZC or 88-89 Integra (SOHC won’t fit without adapter)
