1 - 7 of 7 Posts
crx
does anyone know what to do with the zc oil pump,i heard of a trick with the spring in the oil pump,can someone help me out, i already blew a engine because of a weak oil pump.thanks
88 ED6
Its called shimming. You put a 1/8th or 1/16th spacer that makes the spring stiffer. There was a thread about this a few days ago I believe. If not, search around on this site and H-T.
staticchmbr said:
you can look here:
endyne
unfortunately, it doen't say anything about the washer in the spring trick. i know it can be done, but i can't get my pump apart all the way...
anyone know how to do it??
Are you having trouble getting the phillips head screws out of the back or what? If that's the case you need a impact screw driver...
1 - 7 of 7 Posts
