1 - 12 of 12 Posts
90 crx si/96 accord
Measurements taken with a cheapy H.F. digital caliper.
Shameless showcase of something i just got back from the machine shop ;)
I Will be updating specs on the o ring later, I destroyed mine on removal, so I will source another one, along with a d16a6 orifice to verify interchange.
90 crx si/96 accord
No, this is the original unit, another member had asked for measurements, I will order one for the d16a6, and also a b18. The d16a1 has been discontinued, and part numbers dont match zc for the a6
90 crx si/96 accord
Looks like I wont be ordering an a6, or a b18 for that matter, it just might be a dohc d16 specific item.
At least the o rings haven't been discontinued
Meat Popsicle
91 CRX Si
Yeah, I bought a D16A6 orifice and the passage itself is quite different. The DOHC ZC, D16A1 has a much bigger opening and the D16A6 (I guess because it is installed in the cylinder head instead of the engine block?) has a smaller orifice.
The A6 orifice is also installed in the block. If I had to guess, I’d imagine the orifice passage is larger on the D16A1 and DOHC ZC due to the heads requiring more oil due to the additional cam.
1 - 12 of 12 Posts
