hey guys, I just picked up a dohc zc.
without opening the engine, what numbers can I expect to make with a little 14b turbo?
would 250 be reaching? wheel.....
also, what is the most appropriate rev limiter? 7500???
thanks
matt
89 EF 4wd sedan
thanks
matt
7500 is factory fuel cut. I wouldn't push much past 10lbs. Your setup and dyno will effect what kinda of numbers you see from that boost.
cool cool, im not really looking for numbers on this one....just a fun, fast car that spools up...instantly.
90 crx si/96 accord
The bottom end is treated relatively the same as any other d16, 200 horse in the general consensus for "safe and relaible" previous members (lurker [iirc]) made 250 on the stock engine for many years , but with any engine , it's all in the tune.
The ball and socket valve train does limit raising the rpms, people have gone higher, but, that's your call.
The 14b is a good choice if your looking for a fun street able , near instantaneous boost, that carries out through the rpm range, I enjoy my zc with the 14b very much
