1 - 3 of 3 Posts
G
Discussion Starter · #2 ·
Crapple67 said:
Hey I have a 1992 Civic Lx (manual) I would like to swap the dohc zc engine into it. If found a obd1 zc engine and tranny on ebay here. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2435157804&category=40931
Will my mounts and shift linkage work with it? Are there any parts I will need to pick up other than the engine and belts?
Everything will work and line up and ready to bolt on,But i have herd about werid things happen with the ECU and the gears in the transmission,I would recommend a Si or the zc transmission and getting the zc ecu so you have no problems down the line and you get the full potential.
G
Oh hey and also the dohc zc doesnt have 145hp like the ebay item says,black top is 130 and brown top is 135hp but you need the black top with the gray plug = obd-1
1 - 3 of 3 Posts
