1 - 20 of 21 Posts
Does anybody know who makes a good port matched header for the dohc zc???
The ports are miss aligned by aprox 8mm.
The only ones I have found are obx ss style header and still not sure on if they are correct on the title or like all the others that say fit all d series engines sohc and dohc 88-00 with is B.S.
Any info would be awesome thanks
(eddcartes: ediited your post. if you read the rules you will know why. please take your time and read them.)
90 crx si/96 accord
You should delete your comment about the lower covers.. there is a fs/wtb forum but u need to meet the credentials first...
Zc aftermarket support is very limited.
I'm assuming your talking about the exhaust manifold?. All the sohc d headers bolt right up...and the 8mm difference is quiet an exaggeration. 20-30 minutes with a dremel and you'll be fine.
OEM manifolds are still floating around. But they are few and far between.
Yes but I don't want to grind away at a header... yes it will be fine I have done it before and built lots of d series engines. I have lots of Oem zc header style manifolds. But I was wanting one which needed no fabricating at all. 8mm is the exact off set of the zc sport header flange on the zc dohc ports.
\/Your Mom Was Here\/
Vibe GT
You can grind away at a DC header to port match, or you can use a stock DOHC ZC manifold/pipe which flow good for a factory header but just doesn't look pretty.
Or have someone custom make you one for $$$.
If you don’t mind buying used and up for some hunting, you can find used ZC headers from the Euro and JDM markets floating around sometimes. I managed to pick up one made by RS*R a little while ago.
As far as I know there are no current big volume sales header makers still building them, your best bet if you really don’t want to port out a regular D16 header is to have one custom made, but I assume it will be expensive.
Did the zc dohc "euro" come with a stock steel tube header (not cast)... ?
If so where could I get one and does anyone have any pictures
97 honda HX-07 STI
Wait are you say SOHC D d series Exahust manifold will bolt to dual overhead ZC?....If so that is kind of a cool thought.
Vibe GT
Bolts up fine but the ports are off and need a little TLC with a grinder/dremel.
Nope it is 8mm... Anyways don't need people telling me it can't be or shouldn't be ... It is and I wanted to know what header will fit I have found one thanks guys
97 honda HX-07 STI
There is a Real NICE OBX R ZC Header on Ebay like 200 bucks buy now
93 Legend L Coupe.
I don't believe you. *shrugs*
I don't understand why you are so adamant on having a header specifically designed for a ZC/d16a9/d16a8, when an SOHC with some very mild modification will do exactly the same job, with very little/no deduction in performance.
SOHC mainfolds are in abundance and on the most part are relatively cheap.
Any reason why you dont want to mod an SOHC manifold?
Discussion Starter #19
1# tech at the track I race at...
2# I'm picky
3# performance is a must
4# can't a guy just get a straight answer with out people questioning you're choices...
BTW --- Acid beaver I don't care what you think or what you believe.
90 crx si/96 accord
First 3 are all understandable valid points.
However #4...this is the first report of such a large offset that I've heard of ...pretty sure as well for a lot of other people...
So with that said...its gonna be pretty tough to get a straight answer... just post up a couple pics so.we can see what your talking about.
I personally have hogged out 3 different steel tube manifolds ( sohc) and the offset was not as dramatic as your talking about...ya the cast HF manifold required more finesse ...but still workable
1 - 20 of 21 Posts
