1 - 12 of 12 Posts
I need to find a head gasket for my dohc zc. Is standard bore at 75 mm and all I can find is 75.5 mm. Anyone have any suggestions
you can safely use 75.5mm bored gaskets.
but I found a couple standard 75mm just now.
<cough> ebay <cough>
\/Your Mom Was Here\/
Vibe GT
Have you measured the OEM one? The D16Z6 head gasket at OEM bore is around 75.81, leaving enough room for the 75.5 pistons you plan to use.
EDIT: Also golden eagle bores OEM gaskets to spec of you need one.
I would personally get a whole fel-pro head set for an 89 Integra 1.6. comes with valve seals, cam seals, cover gasket, head gasket ect. I think they are like $50 on rock auto. That's what i used on my zc with no issues.
1 - 12 of 12 Posts
