1 - 9 of 9 Posts
Hi all, thanks for having me - I'm after a 22mm crank pulley with all accessories (AC/PS) for my DOHC ZC. I'm struggling to find one in New Zealand. I'm happy to go after-market - but even an OEM part number would be great if anyone knows it. My parts guy needs something to work with! It's for my DOHC ZC swapped JDM Beagle!
I can't post images yet, so you'll have to wait and see!
ED6&7. EE4&5, MB1
use a d16y8 pulley and make 2 new timing marks equal distance from the last one so you get your 16 degrees mark. fyi the y8 pulley has a better damper and smaller in diameter, less rotational mass is less centripital force
this was my y8 pulley on my dohc zc
Did Y8 also come with 22 mm crankshaft snout?
I thought all D16 after 88 did get 24 mm snout.
Are the USDM integra d16a1's close enough in the bloodline to share snout dimensions?
Might be worth the search. They pop on US ebay.com every once in awhile
1 - 9 of 9 Posts
