1 - 16 of 16 Posts
89 Crx
I picked up an issue of SCC, and they mentioned a setup that replaces your syncros. It looked badass. Its under the f22 buildup, where they put the d16a1 tranny to the f22, a 17:1 9400 RPM buildup.
Sorry its vague, but im tired. lol.
Let me know if anyone knows.
T
Is this the issue that's on the newstands currently??
I've got an F22A4 sitting up at my buddies garage that I've yet to tinker with... hmmm.
- James
WRONG,
lift off gas, slam shift, back on the gas.
PS the tranny pictured is a 94+ GSR gearbox. I've talked Bisi and Jamie recently :)
89 Crx
90si said:
dog cut gears = you HAVE to match rev on every shift
and dont miss
That would only be true if you had no syncros at all.
9
funny every dog cut tranny I've ever driven
enduro races needed to be match shift rpm up and down
B
Match rev to down shift. But bone is right lift gas, shift, slam it back down.
9
i give i guess that lifting the gas when upshifting is not macthing the rpm
and the "lift" is about 1/10th of a second worth of 1-2mm on the pedle
also with double cut dog gears, no real need to rev match on the down shifts.
I watch Keith G. of HASport run a entire 30 minute heat at 2003 Runoffs with out a clutch!!!!!! The hyd. clutch line busted as the group was entering the course.
9
LOL that story went round the pits more then once and yes thats the
real joy of dog gears is @ song you dont use the clutch , I think
I'll be @ the ohio this year .. beer ?
I was inside the tent between Jamie, -TJ and Keith, then watched Kirk go though a CG box! Jamie asked WTF I was doing without knowing me........I replied "LEARNING"..........
this will be the last year for the run-offs at Mid Ohio, I'm camping I think, even if it is in my car!
Beer? Bring that expensive CANUCK beer if you can!!!!!!
Or drink 1.5 times as much US beer, same effect!
9
LOL I'll see if the nasty guards will let me bring the "dreaded maple beer" with me ;)
I'll be with Bud's 3rd gen blue/purple rotary this year, next year I'll most likley
have a nasty 3rd gen civic / b18b beast. (just tuneing it now) so a summer @
local track (mission raceway) for break-in +local crew chief for 2 rotary beasts
ug
1 - 16 of 16 Posts
