1 - 3 of 3 Posts
Problem is I can't get my drivers side i-shaft to go in the diff (I-shaft is too big ). I habe B16a and my tranny is a B series y1 with unknown LSD I installed. I have teg i-shaft now. I was wondering if someone knew about the ZC shaft input bore. Maybe the zc input shaft is more small and that would work. Any ideas. Thanks
1996 Civic Type DX
This is D-series.org...
DOHC ZC uses the same shaft spline but it won't work on a B series block.
Do you have a D16A1 shaft now or a B18A/B18B shaft?
I got it worked out. For some unknown reason I had to fully seat the i-shaft with a sledge hammer. Then it bolted up. I don't remember it being this damn tight in the OEM differential. Its a B18b shaft. I think its a cusco diff.
1 - 3 of 3 Posts
