21 - 25 of 25 Posts
Discussion Starter #21
If $695 for a reman trans is too much, then you shouldn't be trying for 400 whp. Add a MFactory Torsen LSD for $700 retail and you'd have a trans ready for 400 whp, but I'd upgrade to carbon synchros while in there as well, another $200 retail.
Is an LSD Necessary for a build like mine? Also, idk if the trans has carbon synchros already, I think ill inquiry about that before the purchase. If they are not, how should I approach this issue considering my situation with rebuilding? Are there any cheaper LSD's on the market those good recommendations?
LSD means you wont eat a guard rail when you decide to floor it on the interstate
It is a fantastic thing to have, even on a very mild 200whp setup
cheap
fast
reliable
you can only pick 2....and judging by your posts, youre trying for fast and reliable......so guess what it wont be
1996 Civic Type DX
I recommend carbon synchros. Most boosted builds tend to carry power to a higher RPM than stock. D synchros are already small (D 1/2 are the same size as B 3/4) so a synchro with more bite only helps prolong the life of the synchro itself. There are no cheaper LSD's that professionals will install. There is one out there but it is a hunk of crap for many reasons.
If you want to know more about getting a trans built you can check my site out and email me, www.wd-r.com
The reman'd transmissions Synchrotech sells are not all the same and not necessarily remanufactured. The industry standard for a transmission to be considered remanufactured is 75% of the parts replaced with new parts. Synchrotech charges $400 for labor and a master rebuild kit is $350-$400 depending on which synchros you get. Add in the cost of a core trans (they have a super cheap source since they're in SoCal, so $75 for a core) and shift forks and you can see that they're either taking a loss on it or not replacing all of the wear items that their master rebuild kits include.
21 - 25 of 25 Posts
