1 - 6 of 6 Posts
eg
building a z6 block with p29 but now my main bearings dont match up. i bought OEM main bearings and i did match them the color their supposed to be.
so is the wrist pin higher or lower on the rod? will that mess with the main bearing clearance?
eg
i installed p29 pistons and i bought the right color main bearings but now my clearance are way off. the crank is loose in there
any thoughts
77 civc cvcc
I think you are talking about the rods right? Ive heard you need to use the integra bearings. What year integra did you take them out of? The good rods are from 86-87. The piston has nothing to do with bearing clearance, please clarify a bit:)
racist-bigot-sexist-homophob
Judging from all the useful info in this thread I'm going to assume you used the rods the pistons were on to begin with? If that's the case then yes you could probably expect your rod bearing clearances to be messed up.
eg
well found the problem. i forget to install the thrust washer. i know i know i'm retarded but i was so frustrated that i just didn't know what happen. so i stop working on it and this morning went back at it with a clean mind and its done
Thanks for the advise
1 - 6 of 6 Posts
