1 - 12 of 12 Posts
My brakes don't work well at all. I never really realized until i get in my other civics and my brakes work amazing.
I replaced the rotors and pads and it helped a little but still the pedal takes a while to engage the brakes(yes i have bled the system, with the traditional method and with a vaccum pump), and the car needs way more pedal pressure to get the same amount of braking force that i get on my other DD civic.
Question: The other day my friend asked if i had a check valve on my brake booster to protect it from boost. I said i have no idea...but sounds reasonable that the brake booster shouldnt see 25psi :S
please weigh in if you have any insight on this! I need brakes!! 350whp and not being able to stop is not the best idea in the world.
any leaks any where on the brake lines? hoses pinched? look over it all again..nvr heard any body have a problem like this cuz there boosted
i don't think i have a check valve...thats the thing im asking...do i need one going in to the brake booster...???
it may have gotten removed when i first did theturbo install like 4 years ago.
Jeep wrangler DD
On 96-00 civics the check valve is inside the vacuum line. If you have replaced the line to the booster, then you most likely need a check valve.
Jeep wrangler DD
No shit? I never knew that. Doesn't seem like a honda-ish thing to do.
yep. If I were at home, I'd take a pic. I snagged one from the junkyard when I was tucking my bay because it looked better than having the big check valve on there. Pic soon
well, i def didn't know that. Because i looked and didn't see any check valve, i'll have to take the line off and see.
So answer in short is...yes boost can hurt brake booster...otherwise there wouldnt be a check valve there. correct....
1 - 12 of 12 Posts
