civic
i have a 92 civic dx sedan will a d16 engine will bolt directly in using stock ecu and tranny(automatic)? will it perform good? what would be the best upgrade to the engine i could do to produce 20 to 40 more hp? oh my stock engine is a d15b7(not such a good engine huh)!
IT will drop right in. May need to change a couple plugs but thats about it.
'95 Civic dx
all depends on which obd engine you are going to put in... the d16z6 will work... its the vtec engine in that year model civic... all you would have to wire is the vtec... any other d16 would require a different engine harness/ecu... unless you used all of your current components (intake manifold, distributor etc)
civic
okay so which plug most likely i would have to change? and how could i wire the vtech up?
civic
